[PROJ] Proper projection system for Aruba
Jelmer Baas Jelmer.Baas at speerit.nl
Sun Feb 9 11:18:04 PST 2020
Hi Jochem,
Thank you for the information. I'll dig through their documentation and contact them.
Here's to hoping I can provide the proj string, later on.
Regards,
Jelmer Baas
From: Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>
Sent: vrijdag 7 februari 2020 17:31
To: Jelmer Baas <Jelmer.Baas at speerit.nl>; proj at lists.osgeo.org
Subject: RE: Proper projection system for Aruba
Hi Jelmer,
Aruba's CRS is a local TM projection with its central meridian through the Hooiberg. Unfortunately it is not in the EPSG registry.
An approximate transformation is available in the PCTrans software by the Dutch Hydrographic Service:
https://english.defensie.nl/topics/hydrography/documents/applications/2018/06/06/pctrans5_20180601
If you want to use PROJ, the transformation parameters of PCTrans can probably be found in de documentation of the software or obtained by sending a message to NSGI:
https://www.nsgi.nl/over-ons/nsgi/contact
Precise (sub metre) transformation parameters are available at the local authorities DLV, and more precise (centimetre) transformation parameters should be computed for DLV this year. However, I'm not sure if they share these. Contact information can be found here:
https://www.overheid.aw/home-ned/departementen_46763/item/dienst-landmeetkunde-en-vastgoedregistratie-dlv_4615.html
If this contact information is outdated, you can contact NSGI (see above) to ask to get you in touch with DLV.
Kind regards, Jochem
From: PROJ <proj-bounces at lists.osgeo.org<mailto:proj-bounces at lists.osgeo.org>> On Behalf Of Jelmer Baas
Sent: vrijdag 7 februari 2020 16:01
To: proj at lists.osgeo.org<mailto:proj at lists.osgeo.org>
Subject: [PROJ] Proper projection system for Aruba
Hello,
I'm trying to convert coordinates from what seems to be a custom projection system in Aruba, without much luck.
In their drawings, they have data around 3000, 18000. Whatever existing projection system I use (EPSG 24819, EPSG 32619), I end up at a completely different location.
For example:
echo 2936 18088 | cs2cs +proj=utm +zone=19 +ellps=intl +towgs84=-216.408,279.243,-203.231,-8.56912,40.8756,-12.5593,15.8909 +units=m +to +proj=webmerc +datum=WGS84
-8178296.58     17850.76 22.52
echo 2936 18088 | cs2cs +proj=utm +ellps=intl +towgs84=-216.408,279.243,-203.231,-8.56912,40.8756,-12.5593,15.8909 +units=m +to +proj=webmerc +datum=WGS84
-830835.88      16729.91 101.08
This is way outside the expected area. In 3857, the data should be somewhere between
-7800000, 1417000
-7777000, 1393000
I do have the attached ".gtf" files, but I'm unsure how to apply this in proj. Is the above string correct? What am I missing?
Any help would be greatly appreciated.
Regards,
Jelmer Baas
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200209/03d2f986/attachment.html>
More information about the PROJ mailing list
