[PROJ] Motion: promote PROJ 6.3.1RC1 to final release
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Wed Feb 12 03:47:34 PST 2020
Why aren't the Dutch 2018 grids included? And why aren't at least the 2008 grids used instead? It looks like cs2cs EPSG:4937 +to EPSG:7415 uses no grid at all, but a 7 parameter transformation, introducing errors up to 25 cm horizontally and large errors vertically.
What can I do to help to make cs2cs EPSG:4937 +to EPSG:7415 give the correct results in 6.3.1 or 7.0.0?
Kind regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ
