[PROJ] Adding new projection to Proj4
Martin Desruisseaux
martin.desruisseaux at geomatys.com
Sun Feb 16 05:52:01 PST 2020
I think Alessandro was proposing to add a new "projection method" (i.e.
another set of mathematical formulas for doing the projection). This is
a different work than assigning an EPSG code, which is more about
setting parameter values to use with pre-existing formulas. If this is
the case, then Alessandro's proposal and EPSG change request would be
orthogonal tasks.
Martin
Le 16/02/2020 à 13:41, Jeff McKenna a écrit :
> Hi Alessandro,
> A new projection can be added into the EPSG registry by filing a
> change request at: http://www.epsg.org/EPSGDataset/Makechangerequest.aspx
> I have went through that process several times now, to add a new
> projection into EPSG, that is then automatically leveraged by software
> projects, such as PROJ. Of course it takes time, first for the EPSG
> committee to review your request, and then also for the new projection
> to propagate to all software projects.
> -jeff
More information about the PROJ
