[PROJ] Adding new projection to Proj4
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun Feb 16 06:49:56 PST 2020
ok thanks for clarifying Martin. -jeff
On 2020-02-16 9:52 a.m., Martin Desruisseaux wrote:
> I think Alessandro was proposing to add a new "projection method" (i.e.
> another set of mathematical formulas for doing the projection). This is
> a different work than assigning an EPSG code, which is more about
> setting parameter values to use with pre-existing formulas. If this is
> the case, then Alessandro's proposal and EPSG change request would be
> orthogonal tasks.
> Martin
> Le 16/02/2020 à 13:41, Jeff McKenna a écrit :
>> Hi Alessandro,
>> A new projection can be added into the EPSG registry by filing a
>> change request at: http://www.epsg.org/EPSGDataset/Makechangerequest.aspx
>> I have went through that process several times now, to add a new
>> projection into EPSG, that is then automatically leveraged by software
>> projects, such as PROJ. Of course it takes time, first for the EPSG
>> committee to review your request, and then also for the new projection
>> to propagate to all software projects.
>> -jeff
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Jeff McKenna
MapServer Consulting and Training Services
https://gatewaygeomatics.com/
More information about the PROJ
