[PROJ] Transverse and oblique Mercator
Kristian Evers kreve at sdfe.dk
Sun Jan 19 03:28:29 PST 2020
Pierre,
You can download a digital copy of Snyders book at https://pubs.er.usgs.gov/publication/pp1395
/Kristian
-----Original Message-----
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Pierre Abbat
Sent: 19. januar 2020 07:14
To: proj at lists.osgeo.org
Subject: Re: [PROJ] Transverse and oblique Mercator
On Wednesday, 15 January 2020 18.11.24 EST Melita Kennedy wrote:
> John Snyder discusses 4 different oblique Mercator implementations on page
> 162 of his book Flattening the Earth. Rosenmund's was first and is used in
> Switzerland. It's not quite the same as Hotine's which is used in Alaska,
> but it's close enough that Esri, at least, is using Hotine's version for
> Switzerland. Madagascar uses Laborde's version. It converts to a conformal
> sphere, then uses a spherical transverse Mercator, and finally a 3rd-order
> complex-algebra transformation to make it oblique. It cannot be emulated
> with Hotine with a reasonable accuracy. Snyder also lists one designed by
> Cole for Egypt, but it's not in common use.
http://mapref.org/ObliqueMercatorProjection.html says that Rosenmund's version
is simply a conformal projection from the ellipsoid to the sphere, followed by
an oblique Mercator projection of the sphere. That's easy.
Should I get Snyder's book? Your book?
Pierre
.i toljundi do .ibabo mi'afra tu'a do
.ibabo damba do .ibabo do jinga
.icu'u la ma'atman.
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
