[PROJ] Axis Order in Custom Projection
Paul Harwood
runette at gmail.com
Thu Jul 9 08:11:43 PDT 2020
Thanks, I'll check it out.
On Thu, 9 Jul 2020 at 15:25, Even Rouault <even.rouault at spatialys.com>
wrote:
> Paul,
> you could do that by building a pipeline
> ( https://proj.org/operations/pipeline.html )
> chaining the tmerc projection with a axisswap operation
> ( https://proj.org/operations/conversions/axisswap.html )
> Even
> > Hi
> > I am working on a project to put GIS data into VR in Unity (see
> virgis.org
> > for more info - very early stages).
> > I am using Proj to convert Geospatial data into internal VR Space
> > coordinates for a model. I did this by defining a custom projection for
> the
> > internal model space ( of the form of "+proj=tmerc +datum=WGS84 +units=m
> > +no-defs +lat_0=53.316200583246534 +lon_0=-1.791218230167096" where the
> > lat_0 and lon_0 figures depend on the location of the model.).
> > This is working well in both directions.
> > However - one constant and annoying fact is that whilst all Geospatial
> CRS
> > are "Z-up" i.e. altitude is the Z dimension, VR space is "Y-up". It is
> > a purely procedural thing to swap the axis but it is a constant
> > irritation and cause of failures!
> > The ideal solution would be if the Proj coordinate operation produced
> > coordinates in "eun" axis order! Would solve a lot of problems. I did try
> > this to see if it was possible but (not unsurprisingly) got an error.
> > Is there any way to do this? Or is it so far from the expected usage that
> > it is just not possible?
> > Thanks in advanced for any and all comments.
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200709/a5e6765b/attachment.html>
More information about the PROJ
