[PROJ] proj-data is 500MB
Jürgen E. Fischer jef at norbit.de
Fri Jul 24 00:31:41 PDT 2020
Hi Idan,
On Fri, 24. Jul 2020 at 10:22:56 +0300, Idan Miara wrote:
> Jürgen suggests proj 7.1 can't be included in OSGeo4W/QGIS installer
> because proj-data is 500MB, which is too big.
> Is it intentionally so big?
It includes all the grids.  And it's not a dependency.  The grids can also be
downloaded dynamically, so using proj-data is probably only intended to be used
if that's not possible for some reason.  You can also interactively download
the grids that you need via cdn.proj.org.  QGIS does currently not support the
dynamic download and we don't know which grid the users will need upfront - so
either including none or all seems to be the only option.  Given that QGIS
previously shipped several grids by default, shipping none probably isn't an
option either - as that would break some installations.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden              https://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200724/24cf660d/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200724/24cf660d/attachment.ksh>
More information about the PROJ mailing list
