[PROJ] Is DERIVEDPROJCRS implemented?
Gabriel De Luca pablogabrieldeluca at gmail.com
Thu Mar 12 21:41:48 PDT 2020
Hi PROJ list,
  I am trying to create *DERIVEDPROJCRS* WKT representations, but without
success.
  The attached text file is the example definition given in section 14.4.2
(with some quotation marks corrected, and I don't know if well corrected)
of the http://docs.opengeospatial.org/is/18-010r7/18-010r7.html document.
 projinfo (Rel. 6.3.1, February 10th, 2020), OSGeo4W Win10 install,
returns:
Too many parameters: BASEPROJCRS[NAD27 / Texas South Central,
  I don't know if *DERIVEDPROJCRS* is already implemented or if there is
something wrong with this representation.
Thank you for all your work!
Kind Regards,
Gabriel
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200313/c711f87c/attachment.html>
DERIVEDPROJCRS["Gulf of Mexico speculative seismic survey bin grid", BASEPROJCRS["NAD27 / Texas South Central", BASEGEOGCRS["NAD27", DATUM["North American Datum 1927", ELLIPSOID["Clarke 1866",20925832.164,294.97869821, LENGTHUNIT["US survey foot",0.304800609601219] ] ] ], CONVERSION["Texas South Central SPCS27", METHOD["Lambert Conic Conformal (2SP)",ID["EPSG",9802]], PARAMETER["Latitude of false origin",27.83333333333333, ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8821]], PARAMETER["Longitude of false origin",-99.0, ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8822]], PARAMETER["Latitude of 1st standard parallel",28.383333333333, ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8823]], PARAMETER["Latitude of 2nd standard parallel",30.283333333333, ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8824]], PARAMETER["Easting at false origin",2000000.0, LENGTHUNIT["US survey foot",0.304800609601219],ID["EPSG",8826]], PARAMETER["Northing at false origin",0.0, LENGTHUNIT["US survey foot",0.304800609601219],ID["EPSG",8827]] ] ], DERIVINGCONVERSION["Gulf of Mexico speculative survey bin grid", METHOD["P6 (I = J-90°) seismic bin grid transformation",ID["EPSG",1049]], PARAMETER["Bin grid origin I",5000,SCALEUNIT["Bin",1.0],ID["EPSG",8733]], PARAMETER["Bin grid origin J",0,SCALEUNIT["Bin",1.0],ID["EPSG",8734]], PARAMETER["Bin grid origin Easting",871200, LENGTHUNIT["US survey foot",0.304800609601219],ID["EPSG",8735]], PARAMETER["Bin grid origin Northing", 10280160, LENGTHUNIT["US survey foot",0.304800609601219],ID["EPSG",8736]], PARAMETER["Scale factor of bin grid",1.0, SCALEUNIT["Unity",1.0],ID["EPSG",8737]], PARAMETER["Bin width on I-axis",82.5, LENGTHUNIT["US survey foot",0.304800609601219],ID["EPSG",8738]], PARAMETER["Bin width on J-axis",41.25, LENGTHUNIT["US survey foot",0.304800609601219],ID["EPSG",8739]], PARAMETER["Map grid bearing of bin grid J-axis",340, ANGLEUNIT["degree",0.0174532925199433],ID["EPSG",8740]], PARAMETER["Bin node increment on I-axis",1.0, SCALEUNIT["Bin",1.0],ID["EPSG",8741]], PARAMETER["Bin node increment on J-axis",1.0, SCALEUNIT["Bin",1.0],ID["EPSG",8742]] ], CS[ordinal,2], AXIS["Inline (I)",northNorthWest], AXIS["Crossline (J)",westSouthWest] ]
More information about the PROJ mailing list
