[PROJ] How does proj deal with ellipsoid with respect to reprojection
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Mon Mar 30 01:12:05 PDT 2020
Charles,
Thanks, that is very interesting! It shows that the gnomic projection gives quite good results, despite neglecting the flattening. For point in polygon with 1 mm accuracy, segments of 50 km are allowed. This makes it probably more efficient than adding additional points every 200 m for +proj=lonlat. Since geodetic knowledge is becoming more and more scarce in the Netherlands, I probably keep advising the use of segments of maximum 200 m to avoid misinterpretation by laymen.
Regards, Jochem
-----Original Message-----
From: Charles Karney <charles.karney at gmail.com> On Behalf Of Charles Karney
Sent: zondag 29 maart 2020 16:17
To: Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>; proj at lists.osgeo.org
Cc: Pierre Abbat <phma at bezitopo.org>
Subject: Re: [PROJ] How does proj deal with ellipsoid with respect to reprojection
Jochem,
Here's the equivalent table for the ellipsoidal gnomonic projection as it applies (roughly) to the Netherlands.  I use the ellipsoidal gnomonic projection centered at lat = 52 deg.  I considered geodesic line segments of length S whose centers are 500 km from the center of the projection.  I then computed D, the maximum deviation of the straight line in the projection from the geodesic.
       S     max-deviation
     500 km   99 mm
     200 km   16 mm
     100 km    4 mm
      50 km  985 um
      20 km  158 um
      10 km   40 um
       5 km   10 um
       2 km    2 um
       1 km  394 nm
      500 m   99 nm
      200 m   18 nm
On 3/29/20 2:28 AM, Lesparre, Jochem wrote:
> Doing point in polygon in a projection will result in occasional wrong
> conclusions. A point near de edge can seem to be inside the polygon
> while it's outside, or the other way around, since a straight line in
> the projection deviates from the geodesic.
> I analysed this problem for the Netherlands (51 - 55 degrees north) in
> the azimuthal projection (+proj=sterea) of the national coordinate
> reference system RD (epsg:28992) and in plate-caree projection
> (+proj=lonlat). The deviation depends on the length, orientation and
> location of a polygon segment. I computed the maximum possible
> deviation in the Netherlands for both projections to advise the Dutch
> government not to allow any segments longer than 200 m in a new
> digital storage system for policy and zoning borders.
> Table for the Netherlands:
> Segment length, RD deviation, lonlat deviation;
> 500 km, 160 m, 6 km;
> 200 km, 25 m, 1 km;
> 100 km, 6.4 m, 0.2 km;
> 50 km, 1.6 m, 60 m;
> 20 km, 26 cm, 9.7 m;
> 10 km, 8 cm, 2.4 m;
> 5 km, 3 cm, 60 cm;
> 2 km, 5 mm, 9.7 cm;
> 1 km, 1.3 mm, 2.4 cm;
> 500 m, 0.3 mm, 6 mm;
> 200 m, <0.1 mm, 1 mm;
> 100 m, <0.1 mm, 0.2 mm;
> 50 m, <0.1 mm, <0.1 mm
> This means that when you first split long segments of polygons by
> adding enough points along the geodesic, you could do a point in
> polygon even in lonlat. The required distance between the added points
> depends on the location (latitude). Near the poles it will get a bit
> tricky, as the maximum deviation increases to 50% of the size of the segment length.
> Regards, Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message
More information about the PROJ mailing list
