[PROJ] The state of PROJ C++ 2020
Sebastiaan Couwenberg sebastic at xs4all.nl
Thu May 7 10:03:41 PDT 2020
On 5/7/20 6:31 PM, Søren Holm wrote:
> I do however not understand why the precision and future evolution readiness -
> which are features in inself - is brough into a purely language oriented
> question. I'm quite sure that using C or C++ without the stuff that makes it
> slow can be just as precise as anything else.
You should read this thread:
 https://lists.osgeo.org/pipermail/proj/2018-May/007799.html
> Lastly I just want to say that I did not write these email to start a
> discussion. It was a mere combination of:
> "Hey, thing thing is takes 10 times longer to compile, Why is that?"
>       and
> "If my software projects compile time increased 10 fold I would see it as a
> bug."
Mailinglists are for discussions, issue trackers are for bugs.
If you're concerned about the increased time it takes to build software,
you haven't been building QGIS since before 3.x and you should stay away
from it.
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the PROJ mailing list
