[PROJ] Ellipsoidal orthographic: condition of projectability ?
Even Rouault even.rouault at spatialys.com
Sat Sep 26 03:31:59 PDT 2020
In https://github.com/OSGeo/PROJ/pull/2361, I've implemented the ellipsoidal formulation
of the orthographic projection from the formulas from EPSG guidance note 7-2, but one
missing piece is the condition of projectability.
In the spherical formulation, there is a test to check that a given (lam, phi) is visible from the
projection plane or not.
https://github.com/rouault/PROJ/blob/2e104e092578347de11208e9a3a80a3bf711265d/
src/projections/ortho.cpp#L53
It seems it comes from https://pubs.usgs.gov/pp/1395/report.pdf equation (5-3), page 149
Looking at the formula, one can observe that it is actually the (opposite of the) partial
derivative of y(lam, phi, phi0) with respect to phi0.
But perhaps this is just a coincidence due to the spherical case.
Now, the question... What about the ellipsoidal case:
- Should the exact same formula (Q->sinph0 * sinphi + Q->cosph0 * cosphi * coslam < - EPS10)
of the spherical case be used as well ?
- Or should we compute the partial derivative of y(lam, phi, phi0) with respect to phi0 with
the ellipsoidal formula of y from
src/projections/ortho.cpp#L136 (will not be pretty...)
- something else ?
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20200926/d21e11d0/attachment.html>
More information about the PROJ mailing list
