[PROJ] Compound ESRI+EPSG
Even Rouault even.rouault at spatialys.com
Mon Apr 12 08:49:45 PDT 2021
Javier,
Several options are already possible:
- by name: "NAD_1983_HARN_Adj_MN_Ramsey_Meters + NAVD88 height"
- using OGC URN compound CRS syntax:
"urn:ogc:def:crs,crs:ESRI::103668,crs:EPSG::5703"
That said having "ESRI:103668+EPSG:5703" to work would be good (I can't
remember OGC URN syntax without looking at an example). You could have a
try at that after
https://github.com/OSGeo/PROJ/blob/master/src/iso19111/io.cpp#L6381 with
a new tokens.size() == 3 case.
Even
Le 12/04/2021 à 17:29, Javier Jimenez Shaw a écrit :
> Hi
> I am wondering how to combine a horizontal ESRI crs with a vertical
> EPSG crs. I would say there is no problem if I just create a WKT
> string with the combination, right?
> Let's say ESRI:103668 "NAD_1983_HARN_Adj_MN_Ramsey_Meters" and
> EPSG:5703 "NAVD88 height". Is there any shortcut in projinfo to create it?
> Is there any "compressed" way to identify it? Something like
> Thanks,
> Javier
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210412/64750461/attachment-0001.html>
More information about the PROJ mailing list
