[PROJ] Compound ESRI+EPSG
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Apr 12 14:50:34 PDT 2021
Which version of clang-format are we using?
I am modifying src/iso19111/io.cpp , and a couple of lines not related has
been formatted. My Ubuntu 18.04 (soon will be 20.04) has clang-format-6.0
Javier
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Mon, 12 Apr 2021 at 17:49, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> Several options are already possible:
> - by name: "NAD_1983_HARN_Adj_MN_Ramsey_Meters + NAVD88 height"
> - using OGC URN compound CRS syntax:
> "urn:ogc:def:crs,crs:ESRI::103668,crs:EPSG::5703"
> That said having "ESRI:103668+EPSG:5703" to work would be good (I can't
> remember OGC URN syntax without looking at an example). You could have a
> try at that after
> https://github.com/OSGeo/PROJ/blob/master/src/iso19111/io.cpp#L6381 with
> a new tokens.size() == 3 case.
> Even
> Le 12/04/2021 à 17:29, Javier Jimenez Shaw a écrit :
> Hi
> I am wondering how to combine a horizontal ESRI crs with a vertical EPSG
> crs. I would say there is no problem if I just create a WKT string with the
> combination, right?
> Let's say ESRI:103668 "NAD_1983_HARN_Adj_MN_Ramsey_Meters" and EPSG:5703
> "NAVD88 height". Is there any shortcut in projinfo to create it?
> Is there any "compressed" way to identify it? Something like
> Thanks,
> Javier
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210412/d9756fc8/attachment.html>
More information about the PROJ
