[PROJ] Transforming from epsg:4326 to epsg:31468 produces a 2 meter offset
XCTrails info at xctrails.org
Thu Apr 15 00:32:16 PDT 2021
I have input polygon in epsg:31468 which I need to transform to epsg:4326
My current code boils down to this:
project = pyproj.Transformer.from_crs("EPSG:31468","EPSG:4326",
always_xy=True)
poly = transform(project.transform, poly)
The problem however is that the resulting polygons have a 1-2 meter offset
according to visual inspection in QGIS. On reddit, someone suggested that I
might also need a datum transformation, on the pyproj4 issue tracker
someone said, that datum transformations are no longer needed in PROJ 6+
and that I should ask for clarification here. So here I am ;-)
Can anyone shed any light on why I get these offsets and what I can do to
fix this?
There's no offset if I manually reproject this in QGIS and compare it with
the original.
Thanks,
Armin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210415/c91cc614/attachment.html>
More information about the PROJ mailing list
