[PROJ] Transforming from epsg:4326 to epsg:31468 produces a 2 meter offset
Alan Snow
alansnow21 at gmail.com
Thu Apr 15 05:51:20 PDT 2021
Original question: https://github.com/pyproj4/pyproj/discussions/814
What he is asking is if TOWGS84 parameters are needed for datum
transformations.
Thanks 👍
On Thu, Apr 15, 2021, 2:32 AM XCTrails <info at xctrails.org> wrote:
> Hi,
> I have input polygon in epsg:31468 which I need to transform to epsg:4326
> My current code boils down to this:
> project = pyproj.Transformer.from_crs("EPSG:31468","EPSG:4326",
> always_xy=True)
> poly = transform(project.transform, poly)
> The problem however is that the resulting polygons have a 1-2 meter offset
> according to visual inspection in QGIS. On reddit, someone suggested that I
> might also need a datum transformation, on the pyproj4 issue tracker
> someone said, that datum transformations are no longer needed in PROJ 6+
> and that I should ask for clarification here. So here I am ;-)
> Can anyone shed any light on why I get these offsets and what I can do to
> fix this?
> There's no offset if I manually reproject this in QGIS and compare it with
> the original.
> Thanks,
> Armin
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210415/21d50645/attachment.html>
More information about the PROJ
