[PROJ] World UTM in a proper datum
Javier Jimenez Shaw
j1 at jimenezshaw.com
Sat Apr 17 12:44:17 PDT 2021
Hi
Maybe there is a better place to talk about this, but I do not know which
one. I hope somebody from EPSG is reading this, and may give me a clue.
We have talked many times about the lack of accuracy of WGS84 (EPSG:4326),
the datum ensemble, etc.
The problem is that I miss an accurate equivalent of the projected family
"WGS84 / UTM zone XXY"(EPSG:326XX and EPSG327XX) for XX between 1 and 60
and Y is N or S. It would be nice something similar (a worldwide projected
CRSs on UTM), but over a proper accurate and well defined geographic CRS
(ITRF2014, WGS84(G1762), etc).
Do you know if there is any plan? Or do they exist and I was not able to
find them?
Thanks.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210417/0858f141/attachment.html>
More information about the PROJ
