[PROJ] World UTM in a proper datum
Noel Zinn (cc)
ndzinn at comcast.net
Sat Apr 17 13:24:11 PDT 2021
Unlike an empirically-derived datum transformation (e.g. WGS <> ITRF), which can have different levels of "accuracy" depending how it was derived, a map projection (lat/lon <> N/E) is defined mathematically and is precise, i.e. without error. Having said that, there are better and worse algorithms for UTM, but that's not the question you're asking. In a datum transformation sense UTM will always be as (and only as) "accurate" as the geographicals you convert to N/E. So, use EPSG:326XX and EPSG327XX, but plug in your precise geographicals.
Sent: Saturday, April 17, 2021 2:44 PM
To: proj
Subject: [PROJ] World UTM in a proper datum
Hi
Maybe there is a better place to talk about this, but I do not know which one. I hope somebody from EPSG is reading this, and may give me a clue.
We have talked many times about the lack of accuracy of WGS84 (EPSG:4326), the datum ensemble, etc.
The problem is that I miss an accurate equivalent of the projected family "WGS84 / UTM zone XXY"(EPSG:326XX and EPSG327XX) for XX between 1 and 60 and Y is N or S. It would be nice something similar (a worldwide projected CRSs on UTM), but over a proper accurate and well defined geographic CRS (ITRF2014, WGS84(G1762), etc).
Do you know if there is any plan? Or do they exist and I was not able to find them?
Thanks.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
PROJ mailing list
PROJ at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210417/0c1364da/attachment.html>
More information about the PROJ
