[PROJ] World UTM in a proper datum
    Lesparre, Jochem
    Jochem.Lesparre at kadaster.nl
    Sun Apr 18 07:37:10 PDT 2021
Duncan wrote:
> As an onlooker, I have a question: what is UTM/WGS84 intended to mean? Is it (A) the UTM projection using the WGS84 ellipsoid
as a parameter, or (B)  is it meant to imply also that the coordinates are in a datum that is one of the several labelled WGS84? A is clear and completely unambiguous; B isn't, partly because it is subject to change as data are collected (not to mention plate motions). Data-dependence is also a problem with geoid models: it is why there are so many, after all.
Duncan, I think WGS84-UTM is normally intended to mean both A and B so it is using a datum of WGS84 realisation and the WGS84 ellipsoid. According to ISO and EPSG de ellipsoid is part of the datum, so in that case the answer A and B is the same as just B.
Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210418/adc9b5a9/attachment.html>
More information about the PROJ
