[PROJ] World UTM in a proper datum
Javier Jimenez Shaw j1 at jimenezshaw.com
Sun Apr 18 13:54:28 PDT 2021
Reading some answers, I realized that the term "WGS84" is very polysemic.
To see the different meanings (are there more?), let's use this WKT:
projinfo EPSG:32632 -o WKT1:GDAL -q
PROJCS["WGS 84 / UTM zone 32N",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4326"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",9],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AXIS["Easting",EAST],
    AXIS["Northing",NORTH],
    AUTHORITY["EPSG","32632"]]
We see that WGS84 can be:
 - Spheroid/Ellipsoid (EPSG:7030)
 - Datum (EPSG:6320). A datum ensemble in this case (more about that later)
 - The prefix of all the 6 datums members of that datum ensemble EPSG:6320,
like WGS84(transit) or WGS84(G1762)
 - Geographic CRS (EPSG:4326)
 - The prefix of many projected CRS. All those that have EPSG:4326 as the
base geographic crs, like "WGS 84 / UTM zone 32N"
In addition to that, I met some people using it wrongly
 - Some people use it to refer to any UTM projection over WGS84 (the one
that affects them). They say "WGS84" instead of "WGS84 / UTM zone 30N"
 - As the "one and only" lat-long system
The accuracy problem I mentioned in previous emails is due to the fact that
the datum "WGS_1984" is a datum ensemble, that produces that you are not
sure about which one are you talking about:
https://epsg.org/datum_6326/World-Geodetic-System-1984-ensemble.html
(actually EPSG marks it with an accuracy of 2 m)
The same happens to the associated geographic crs, WGS84 EPSG:4326. And
that "pollutes" all the projected crs that use EPSG:4326 as the geographic
crs.
The last member of that ensemble, WGS84(G1762), has a geographic crs,
EPSG:9057. However, there are no projected crs on it in EPSG.
Cheers,
Javier
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Sun, 18 Apr 2021 at 16:37, Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>
wrote:
> Duncan wrote:
> > As an onlooker, I have a question: what is UTM/WGS84 intended to mean? Is
> it (A) the UTM projection using the WGS84 ellipsoid
> as a parameter, or (B)  is it meant to imply also that the coordinates are
> in a datum that is one of the several labelled WGS84? A is clear and
> completely unambiguous; B isn't, partly because it is subject to change as
> data are collected (not to mention plate motions). Data-dependence is also
> a problem with geoid models: it is why there are so many, after all.
> Duncan, I think WGS84-UTM is normally intended to mean both A and B so it
> is using a datum of WGS84 realisation and the WGS84 ellipsoid. According to
> ISO and EPSG de ellipsoid is part of the datum, so in that case the answer
> A and B is the same as just B.
> Jochem
> Disclaimer:
> De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
> Gebruik van de inhoud van dit bericht door anderen zonder toestemming van
> het Kadaster
> is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan
> verzoeken wij u
> dit direct te melden aan de verzender en het bericht te vernietigen.
> Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
> Disclaimer:
> The content of this message is meant to be received by the addressee only.
> Use of the content of this message by anyone other than the addressee
> without the consent
> of the Kadaster is unlawful. If you have received this message, but are
> not the addressee,
> please contact the sender immediately and destroy the message.
> No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210418/8ce42c39/attachment.html>
More information about the PROJ mailing list
