[PROJ] World UTM in a proper datum
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Mon Apr 19 01:09:04 PDT 2021
Thanks Javier, for the effort of explaining it so clearly to all readers. Two things are missing in your overview, though.
(1) Each lat-lon CRS has 3 different EPSG codes:
* 2D lat, lon (e.g. WGS84: EPSG:4326)
* 3D lat, lon, ellipsoidal height (e.g. WGS84: EPSG:4979)
* XYZ in metres (e.g. WGS84: EPSG:4978)
NB: XYZ is not a projected CRS and the axis are generally not aligned with the earth surface.
(2) There are four Global Navigation Satellite Systems (official abbreviation: GNSS, but commonly all referred to as GPS):
* GPS Navstar by US military with CRS: WGS84
* Glonass by Russian military with CRS: PZ-90
* Galileo by EU (civilian) with CRS: GTRS
* BeiDou by Chinese military with CRS: BDC
The 4 GNSS are managed by organisations of different countries. Using WGS84 as the standard CRS is a political choice. But the choice for WGS84 mostly originates from ignorance about the different world-wide datums. Therefore, the term WGS84 often means: “lat-lon coordinates in any datum, I don’t know which”.
There is a more precise and politically neutral scientific alternative CRS available: ITRS, with most recent realisation ITRF2014 (2D EPSG:9000, 3D EPSG:7912, XYZ EPSG7789). There is no EPSG code for the datum ensemble ITRS, nor projected CRS for ITRF2014 in EPSG.
Jochem
From: PROJ <proj-bounces at lists.osgeo.org> On Behalf Of Javier Jimenez Shaw
Sent: zondag 18 april 2021 22:54
To: proj <PROJ at lists.osgeo.org>
Subject: Re: [PROJ] World UTM in a proper datum
Reading some answers, I realized that the term "WGS84" is very polysemic. To see the different meanings (are there more?), let's use this WKT:
projinfo EPSG:32632 -o WKT1:GDAL -q
PROJCS["WGS 84 / UTM zone 32N",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4326"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",9],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","32632"]]
We see that WGS84 can be:
- Spheroid/Ellipsoid (EPSG:7030)
- Datum (EPSG:6320). A datum ensemble in this case (more about that later)
- The prefix of all the 6 datums members of that datum ensemble EPSG:6320, like WGS84(transit) or WGS84(G1762)
- Geographic CRS (EPSG:4326)
- The prefix of many projected CRS. All those that have EPSG:4326 as the base geographic crs, like "WGS 84 / UTM zone 32N"
In addition to that, I met some people using it wrongly
- Some people use it to refer to any UTM projection over WGS84 (the one that affects them). They say "WGS84" instead of "WGS84 / UTM zone 30N"
- As the "one and only" lat-long system
The accuracy problem I mentioned in previous emails is due to the fact that the datum "WGS_1984" is a datum ensemble, that produces that you are not sure about which one are you talking about:
https://epsg.org/datum_6326/World-Geodetic-System-1984-ensemble.html
(actually EPSG marks it with an accuracy of 2 m)
The same happens to the associated geographic crs, WGS84 EPSG:4326. And that "pollutes" all the projected crs that use EPSG:4326 as the geographic crs.
The last member of that ensemble, WGS84(G1762), has a geographic crs, EPSG:9057. However, there are no projected crs on it in EPSG.
Cheers,
Javier
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Sun, 18 Apr 2021 at 16:37, Lesparre, Jochem <Jochem.Lesparre at kadaster.nl<mailto:Jochem.Lesparre at kadaster.nl>> wrote:
Duncan wrote:
> As an onlooker, I have a question: what is UTM/WGS84 intended to mean? Is it (A) the UTM projection using the WGS84 ellipsoid
as a parameter, or (B) is it meant to imply also that the coordinates are in a datum that is one of the several labelled WGS84? A is clear and completely unambiguous; B isn't, partly because it is subject to change as data are collected (not to mention plate motions). Data-dependence is also a problem with geoid models: it is why there are so many, after all.
Duncan, I think WGS84-UTM is normally intended to mean both A and B so it is using a datum of WGS84 realisation and the WGS84 ellipsoid. According to ISO and EPSG de ellipsoid is part of the datum, so in that case the answer A and B is the same as just B.
Jochem
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
Disclaimer:
Disclaimer:
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210419/933b9895/attachment-0001.html>
More information about the PROJ
