[PROJ] Get possible geoidmodels
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Apr 20 09:47:05 PDT 2021
Hi
Given a vertical CRS, I would like to get the list of possible geoid models
that apply to it.
Is there any way in the C++ API to get that information?
(use case: give the user a list of available geoid models, to select the
desired one).
If not, I am happy to make a PR using an SQL query (that is the only way I
found). The input would be the CRS auth-code, the output a list of strings.
Cheers,
Javier.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210420/82012b24/attachment.html>
More information about the PROJ
