[PROJ] Get possible geoidmodels
Alan Snow
alansnow21 at gmail.com
Tue Apr 20 09:51:14 PDT 2021
Personally, I would like to see the PR added. Past issue on the topic:
https://github.com/OSGeo/PROJ/issues/1841
On Tue, Apr 20, 2021 at 11:47 AM Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Hi
> Given a vertical CRS, I would like to get the list of possible geoid
> models that apply to it.
> Is there any way in the C++ API to get that information?
> (use case: give the user a list of available geoid models, to select the
> desired one).
> If not, I am happy to make a PR using an SQL query (that is the only way I
> found). The input would be the CRS auth-code, the output a list of strings.
> Cheers,
> Javier.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Alan Snow
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210420/dbbd497a/attachment-0001.html>
More information about the PROJ
