[PROJ] Get possible geoidmodels
Even Rouault even.rouault at spatialys.com
Tue Apr 20 09:56:57 PDT 2021
Javier,
No, there's no such function.
I'm wondering if we shouldn't generalize that as a function that returns
all known transformations that have a specified CRS as the source or target
PJ_OBJ_LIST* proj_crs_get_related_operations(PJ_CONTEXT* ctxt, const PJ*
crs, const char* const *options)
Even
Le 20/04/2021 à 18:47, Javier Jimenez Shaw a écrit :
> Hi
> Given a vertical CRS, I would like to get the list of possible geoid
> models that apply to it.
> Is there any way in the C++ API to get that information?
> (use case: give the user a list of available geoid models, to select
> the desired one).
> If not, I am happy to make a PR using an SQL query (that is the only
> way I found). The input would be the CRS auth-code, the output a list
> of strings.
> Cheers,
> Javier.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210420/9f1a0937/attachment.html>
More information about the PROJ mailing list
