[PROJ] ballpark transformation ITRF2014 -> CH1903+
Javier Jimenez Shaw
j1 at jimenezshaw.com
Thu Apr 29 03:04:25 PDT 2021
I tried in master this transformation, and I got surprised that it is just
ballpark.
projinfo -s EPSG:9000 -t EPSG:4150 --spatial-test intersects Candidate
operations found: 1 ------------------------------------- Operation No. 1:
unknown id, Ballpark geographic offset from ITRF2014 to CH1903+, unknown
accuracy, World, has ballpark transformation PROJ string: +proj=noop
There is a transformation from ETRS89 to CH1903+ with 0.1m accuracy. Why is
not using it (nested with ITRF2014 -> ETRS89)?
projinfo -s ETRS89 -t EPSG:4150 --spatial-test intersects
Candidate operations found: 1
Operation No. 1:
INVERSE(EPSG):1647, Inverse of CH1903+ to ETRS89 (1), 0.1 m, Liechtenstein;
Switzerland.
PROJ string:
+proj=pipeline
+step +proj=axisswap +order=2,1
+step +proj=unitconvert +xy_in=deg +xy_out=rad
+step +proj=push +v_3
+step +proj=cart +ellps=GRS80
+step +proj=helmert +x=-674.374 +y=-15.056 +z=-405.346
+step +inv +proj=cart +ellps=bessel
+step +proj=pop +v_3
+step +proj=unitconvert +xy_in=rad +xy_out=deg
Thanks.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210429/ad501698/attachment.html>
More information about the PROJ
