[PROJ] ballpark transformation ITRF2014 -> CH1903+
Even Rouault even.rouault at spatialys.com
Thu Apr 29 03:14:35 PDT 2021
> There is a transformation from ETRS89 to CH1903+ with 0.1m accuracy.
> Why is not using it (nested with ITRF2014 -> ETRS89)?
Because there is no transformation registered between ITRF2014 and
ETRS89 (*), so there's no reason to use the ETRS89 intermediate because
the result would have a unknown accuracy.
(*) actually if you do "projinfo -s "ITRF2014"  -t ETRS89 --spatial-test
intersects", you'll see that it manages to compute transformation paths
for Nordic countries, but this is already using an intermediate ETRF2014
pivot, so PROJ logic wouldn't be able to do ITRF2014 -> ETRF2014 -> ....
-> ETRS89 -> CH1903+, and anyway the area of use aren't compatible
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210429/bb57740c/attachment.html>
More information about the PROJ mailing list
