[PROJ] unresolved external symbol EARTH (windows)
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Jul 14 09:02:46 PDT 2021
This issue is about the same topic:
https://github.com/OSGeo/PROJ/issues/1821
that "stale" closed after 2 months of inactivity.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Wed, 14 Jul 2021 at 12:56, Even Rouault <even.rouault at spatialys.com>
wrote:
> Javier,
> the symbol is CPL_DLL exported and defined in static.cpp. You don't
> mention which type of linking you use: dynamic / static.
> You may perhaps need to define PROJ_MSVC_DLL_IMPORT.
> See the following in proj.h
> #ifndef PROJ_DLL
> #ifdef PROJ_MSVC_DLL_EXPORT
> #define PROJ_DLL __declspec(dllexport)
> #elif defined(PROJ_MSVC_DLL_IMPORT)
> #define PROJ_DLL __declspec(dllimport)
> #elif defined(__GNUC__)
> #define PROJ_DLL __attribute__ ((visibility("default")))
> #else
> #define PROJ_DLL
> #endif
> #endif
> Even
> Le 14/07/2021 à 12:33, Javier Jimenez Shaw a écrit :
> Hi all
> I am using PROJ 8.1.0 in C++ in a library. While linking the unit test in
> Windows (no problem in Ubuntu or macOS), I get this error message:
> psrs.lib(SrsCatalog.cpp.obj) : error LNK2019: unresolved external symbol
> "public: static class std::basic_string<char,struct
> std::char_traits<char>,class std::allocator<char> > const
> osgeo::proj::datum::Ellipsoid::EARTH" (?EARTH at Ellipsoid@datum at proj@osgeo@
> @2V?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@B)
> referenced in function "public: void __cdecl
> pd::srs::SrsCatalog::Impl::populate(void)" (?populate at Impl@SrsCatalog at srs
> @pd@@QEAAXXZ)
> In the same function I am using proj methods like getCRSInfoList or
> createCoordinateReferenceSystem, but not another constant.
> Do I have to do anything special to use/link that? Or is it a problem in
> PROJ?
> This happens in the CI machine. I do not have a Windows local computer to
> reproduce it.
> I solved it easily not using the variable
> osgeo::proj::datum::Ellipsoid::EARTH, but the string "Earth". However, it
> could be interesting if there is any problem in proj code.
> Thanks,
> Javier
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210714/a1b806e0/attachment.html>
More information about the PROJ
