[PROJ] unresolved external symbol EARTH (windows)
Even Rouault even.rouault at spatialys.com
Wed Jul 14 09:10:52 PDT 2021
I guess there must be a way, at least for projects using PROJ CMake
file, to have the PROJ target define PROJ_MSVC_DLL_IMPORT for dynamic
builds. That would be welcome as a PR
Le 14/07/2021 à 18:02, Javier Jimenez Shaw a écrit :
> This issue is about the same topic:
> https://github.com/OSGeo/PROJ/issues/1821
> <https://github.com/OSGeo/PROJ/issues/1821>
> that "stale" closed after 2 months of inactivity.
> .___ ._ ..._ .. . ._. .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> On Wed, 14 Jul 2021 at 12:56, Even Rouault <even.rouault at spatialys.com
> <mailto:even.rouault at spatialys.com>> wrote:
>     Javier,
>     the symbol is CPL_DLL exported and defined in static.cpp. You
>     don't mention which type of linking you use: dynamic / static.
>     You may perhaps need to define PROJ_MSVC_DLL_IMPORT.
>     See the following in proj.h
>     #ifndef PROJ_DLL
>     #ifdef PROJ_MSVC_DLL_EXPORT
>     #define PROJ_DLL __declspec(dllexport)
>     #elif defined(PROJ_MSVC_DLL_IMPORT)
>     #define PROJ_DLL __declspec(dllimport)
>     #elif defined(__GNUC__)
>     #define PROJ_DLL __attribute__ ((visibility("default")))
>     #else
>     #define PROJ_DLL
>     #endif
>     #endif
>     Even
>     Le 14/07/2021 à 12:33, Javier Jimenez Shaw a écrit :
>>     Hi all
>>     I am using PROJ 8.1.0 in C++ in a library. While linking the unit
>>     test in Windows (no problem in Ubuntu or macOS), I get this error
>>     message:
>>     psrs.lib(SrsCatalog.cpp.obj) : error LNK2019: unresolved external
>>     symbol "public: static class std::basic_string<char,struct
>>     std::char_traits<char>,class std::allocator<char> > const
>>     osgeo::proj::datum::Ellipsoid::EARTH"
>>     (?EARTH at Ellipsoid@datum at proj@osgeo@@2V?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@B)
>>     referenced in function "public: void __cdecl
>>     pd::srs::SrsCatalog::Impl::populate(void)"
>>     (?populate at Impl@SrsCatalog at srs@pd@@QEAAXXZ)
>>     In the same function I am using proj methods like getCRSInfoList
>>     or createCoordinateReferenceSystem, but not another constant.
>>     Do I have to do anything special to use/link that? Or is it a
>>     problem in PROJ?
>>     This happens in the CI machine. I do not have a Windows local
>>     computer to reproduce it.
>>     I solved it easily not using the variable
>>     osgeo::proj::datum::Ellipsoid::EARTH, but the string "Earth".
>>     However, it could be interesting if there is any problem in proj
>>     code.
>>     Thanks,
>>     Javier
>>     _______________________________________________
>>     PROJ mailing list
>>     PROJ at lists.osgeo.org  <mailto:PROJ at lists.osgeo.org>
>>     https://lists.osgeo.org/mailman/listinfo/proj  <https://lists.osgeo.org/mailman/listinfo/proj>
>     http://www.spatialys.com  <http://www.spatialys.com>
>     My software is free, but my time generally not.
>     PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210714/c6a27d87/attachment-0001.html>
More information about the PROJ mailing list
