[PROJ] proj8 and NAD27 <-> NAD83 transform
Even Rouault
even.rouault at spatialys.com
Thu Jun 3 03:48:58 PDT 2021
Le 03/06/2021 à 12:37, Kirk Waters - NOAA Federal a écrit :
> Even,
> Thank you very much, that's very helpful. It's along the lines of what
> I was thinking was the problem, but I hadn't gotten far enough to
> realize I could add an entry in the database. The other option is to
> figure out the right EPSG code to pass to GDAL to pretend the
> transform has already happened.
If you use gdalwarp, you can lie a bit and set -s_srs EPSG:2273 to force
"NAD83 / South Carolina (ft)" as the source CRS, and then you'll get the
transformation to NAD27 using the CONUS grid.
Even
http://www.spatialys.com
More information about the PROJ
