[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
Jeff McKenna jmckenna at gatewaygeomatics.com
Mon Jun 28 09:27:56 PDT 2021
Hi Kristian,
RC1 seems to work well on Windows (with MS4W build environment).
I do have a question, if you don't mind me asking here.
With 8.1.0 can I specify a location of the default path for the grid
files?  (in other words, not to use on Windows the ugly/unknown/hidden
path of "C:/Users/name with spaces/AppData/Local"  but to set a nicer
local path with something like PROJ_NETWORK_LOCAL_DIRECTORY [set in
proj.ini or through an environment variable] to a specific directory value)
I'm sure this question has been asked & answered, so please go easy on me :)
thanks, and hello from the east coast of Canada,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-06-25 1:31 p.m., Kristian Evers wrote:
> All,
> I have prepared release candidates for PROJ 8.1.0 and PROJ-data 1.7. Download them here:
> http://download.osgeo.org/proj/proj-8.1.0RC1.tar.gz
> http://download.osgeo.org/proj/proj-8.1.0RC1.zip
> http://download.osgeo.org/proj/proj-data-1.7RC1.tar.gz
> http://download.osgeo.org/proj/proj-data-1.7RC1.zip
> See the PROJ release notes below. The PROJ-data release includes two new grids:
> fr_ign_RAF18b.tif and au_ga_AGQG_20201120.tif. In addition the predecessor for the
> latter grid, au_ga_AGQG_20191107.tif, has been removed.
> Please test the two release candidates and report back your findings either to the
> mailing list or in a GitHub issue.
> /Kristian
> 8.1.0 Release Notes
>   Updates
>   + Database
>     o Update to EPSG v10.027 (#2751)
>     o Decrease DB size by using WITHOUT ROWID tables (#2730) (#2647)
>     o Add a ANALYZE step during proj.db creation allowing for
>       faster lookups (#2729)
>     o Added a PROJ.VERSION metadata entry (#2646)
>     o Added NGO48 (EPSG:4273) to ETRS89 (EPSG:4258) triangulation-based
>       transformation (#2554)
>     o Additions to the norwegian NKG2020 transformation (#2548)
>     o ESRI projection database updated to version 12.8 (#2717)
>   + API additions
>     o Added proj_get_geoid_models_from_database() function that returns a list of
>       geoid models available for a given CRS (#2681)
>     o Added proj_get_celestial_body_list_from_database that returns a list
>       of celestial bodies in the PROJ database (#2667)
>     o Added proj_get_celestial_body_name() (#2662)
>   + Various improvements
>     o proj_trans/cs2cs: If two operations have the same accuracy,
>       use the one that is contained within a larger one (#2750)
>     o Share SQLite database handle among all contexts (#2738)
>     o Add proj/internal/mutex.hpp as compat layer for mingw32 for std::mutex (#2736)
>     o projsync: make it filter out files not intended for the current version (#2725)
>     o Improvements related to DerivedVerticalCRS using Change Unit and
>       Height/Depth reversal methods (#2696)
>     o Update internal nlohmann/json to 3.9.1, and add a CMake option to
>       be able to use external nlohmann/json (#2686)
>     o createFromUserInput(): change name of CRS built from URN combined references to match the convention of EPSG projected CRS (#2677)
>     o Parse compound id with two authorities, like ESRI:103668+EPSG:5703 (#2669)
>     o Added projinfo option --list-crs (supports --area) (#2663)
>     o Added support for hyperbolic Cassini-Soldner (#2637)
>     o Added capability to get SQL statements to add custom CRS in the database (#2577)
>   Bug fixes
>   o Fix 'Please include winsock2.h before windows.h' warning with msys (#2692)
>   o Minor changes to address lint in geodesic.c (#2752)
>   o BoundCRS::identify(): avoid incompatible transformation for
>     WKT1 / TOWGS84 export (#2747)
>   o proj_create(): do not open proj.db if string is a PROJ string,
>     even if proj_context_set_autoclose_database() has been set (#2735)
>   o Fix export of transformation to PROJ string in a particular situation
>     where CompoundCRS are involved (#2721)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
