[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
Even Rouault even.rouault at spatialys.com
Mon Jun 28 09:44:19 PDT 2021
Jeff,
so you are talking about the location of where grids are downloaded
using the projsync utility or the location of the cache.db database used
for on-demand grid downloading ? There isn't an official env variable
for this, but you can nevertheless use the PROJ_USER_WRITABLE_DIRECTORY
env var that is for now tagged "for testing purposes only", although we
could probably upgrade it to a more official status.
Even
Le 28/06/2021 à 18:27, Jeff McKenna a écrit :
> Hi Kristian,
> RC1 seems to work well on Windows (with MS4W build environment).
> I do have a question, if you don't mind me asking here.
> With 8.1.0 can I specify a location of the default path for the grid
> files?  (in other words, not to use on Windows the ugly/unknown/hidden
> path of "C:/Users/name with spaces/AppData/Local"  but to set a nicer
> local path with something like PROJ_NETWORK_LOCAL_DIRECTORY [set in
> proj.ini or through an environment variable] to a specific directory
> value)
> I'm sure this question has been asked & answered, so please go easy on
> me :)
> thanks, and hello from the east coast of Canada,
> -jeff
http://www.spatialys.com
More information about the PROJ mailing list
