[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
Jeff McKenna
jmckenna at gatewaygeomatics.com
Tue Jun 29 05:32:07 PDT 2021
Hi Even,
Testing PROJ_USER_WRITABLE_DIRECTORY has went well, it works on Windows
with custom paths (for projsync & cache.db location). I believe we
should upgrade this env variable for the next PROJ release.
Thanks,
-jeff
On 2021-06-28 1:44 p.m., Even Rouault wrote:
> Jeff,
> so you are talking about the location of where grids are downloaded
> using the projsync utility or the location of the cache.db database used
> for on-demand grid downloading ? There isn't an official env variable
> for this, but you can nevertheless use the PROJ_USER_WRITABLE_DIRECTORY
> env var that is for now tagged "for testing purposes only", although we
> could probably upgrade it to a more official status.
> Even
> Le 28/06/2021 à 18:27, Jeff McKenna a écrit :
>> Hi Kristian,
>> RC1 seems to work well on Windows (with MS4W build environment).
>> I do have a question, if you don't mind me asking here.
>> With 8.1.0 can I specify a location of the default path for the grid
>> files? (in other words, not to use on Windows the ugly/unknown/hidden
>> path of "C:/Users/name with spaces/AppData/Local" but to set a nicer
>> local path with something like PROJ_NETWORK_LOCAL_DIRECTORY [set in
>> proj.ini or through an environment variable] to a specific directory
>> value)
>> I'm sure this question has been asked & answered, so please go easy on
>> me :)
>> thanks, and hello from the east coast of Canada,
>> -jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
More information about the PROJ
