[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
    Even Rouault
    even.rouault at spatialys.com
    Tue Jun 29 05:36:52 PDT 2021
Hi Jeff,
please file a ticket about that
Even
Le 29/06/2021 à 14:32, Jeff McKenna a écrit :
> Hi Even,
> Testing PROJ_USER_WRITABLE_DIRECTORY has went well, it works on
> Windows with custom paths (for projsync & cache.db location). I
> believe we should upgrade this env variable for the next PROJ release.
> Thanks,
> -jeff
> On 2021-06-28 1:44 p.m., Even Rouault wrote:
>> Jeff,
>> so you are talking about the location of where grids are downloaded
>> using the projsync utility or the location of the cache.db database
>> used for on-demand grid downloading ? There isn't an official env
>> variable for this, but you can nevertheless use the
>> PROJ_USER_WRITABLE_DIRECTORY env var that is for now tagged "for
>> testing purposes only", although we could probably upgrade it to a
>> more official status.
>> Even
>> Le 28/06/2021 à 18:27, Jeff McKenna a écrit :
>>> Hi Kristian,
>>> RC1 seems to work well on Windows (with MS4W build environment).
>>> I do have a question, if you don't mind me asking here.
>>> With 8.1.0 can I specify a location of the default path for the grid
>>> files?  (in other words, not to use on Windows the
>>> ugly/unknown/hidden path of "C:/Users/name with
>>> spaces/AppData/Local"  but to set a nicer local path with something
>>> like PROJ_NETWORK_LOCAL_DIRECTORY [set in proj.ini or through an
>>> environment variable] to a specific directory value)
>>> I'm sure this question has been asked & answered, so please go easy
>>> on me :)
>>> thanks, and hello from the east coast of Canada,
>>> -jeff
http://www.spatialys.com
More information about the PROJ
