[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
Even Rouault
even.rouault at spatialys.com
Tue Jun 29 07:11:20 PDT 2021
+1 Even
Le 29/06/2021 à 16:10, Kristian Evers a écrit :
> PSC Members,
> No issues with the two release candidates have been reported so I hereby motion that
> PROJ 8.1.0RC1 and PROJ-data 1.7RC1 be promoted to their final versions.
> I’ll start with my +1.
> /Kristian
>> On 25 Jun 2021, at 18:31, Kristian Evers <kristianevers at gmail.com> wrote:
>> All,
>> I have prepared release candidates for PROJ 8.1.0 and PROJ-data 1.7. Download them here:
>> http://download.osgeo.org/proj/proj-8.1.0RC1.tar.gz
>> http://download.osgeo.org/proj/proj-8.1.0RC1.zip
>> http://download.osgeo.org/proj/proj-data-1.7RC1.tar.gz
>> http://download.osgeo.org/proj/proj-data-1.7RC1.zip
>> See the PROJ release notes below. The PROJ-data release includes two new grids:
>> fr_ign_RAF18b.tif and au_ga_AGQG_20201120.tif. In addition the predecessor for the
>> latter grid, au_ga_AGQG_20191107.tif, has been removed.
>> Please test the two release candidates and report back your findings either to the
>> mailing list or in a GitHub issue.
>> /Kristian
>> 8.1.0 Release Notes
>> Updates
>> + Database
>> o Update to EPSG v10.027 (#2751)
>> o Decrease DB size by using WITHOUT ROWID tables (#2730) (#2647)
>> o Add a ANALYZE step during proj.db creation allowing for
>> faster lookups (#2729)
>> o Added a PROJ.VERSION metadata entry (#2646)
>> o Added NGO48 (EPSG:4273) to ETRS89 (EPSG:4258) triangulation-based
>> transformation (#2554)
>> o Additions to the norwegian NKG2020 transformation (#2548)
>> o ESRI projection database updated to version 12.8 (#2717)
>> + API additions
>> o Added proj_get_geoid_models_from_database() function that returns a list of
>> geoid models available for a given CRS (#2681)
>> o Added proj_get_celestial_body_list_from_database that returns a list
>> of celestial bodies in the PROJ database (#2667)
>> o Added proj_get_celestial_body_name() (#2662)
>> + Various improvements
>> o proj_trans/cs2cs: If two operations have the same accuracy,
>> use the one that is contained within a larger one (#2750)
>> o Share SQLite database handle among all contexts (#2738)
>> o Add proj/internal/mutex.hpp as compat layer for mingw32 for std::mutex (#2736)
>> o projsync: make it filter out files not intended for the current version (#2725)
>> o Improvements related to DerivedVerticalCRS using Change Unit and
>> Height/Depth reversal methods (#2696)
>> o Update internal nlohmann/json to 3.9.1, and add a CMake option to
>> be able to use external nlohmann/json (#2686)
>> o createFromUserInput(): change name of CRS built from URN combined references to match the convention of EPSG projected CRS (#2677)
>> o Parse compound id with two authorities, like ESRI:103668+EPSG:5703 (#2669)
>> o Added projinfo option --list-crs (supports --area) (#2663)
>> o Added support for hyperbolic Cassini-Soldner (#2637)
>> o Added capability to get SQL statements to add custom CRS in the database (#2577)
>> Bug fixes
>> o Fix 'Please include winsock2.h before windows.h' warning with msys (#2692)
>> o Minor changes to address lint in geodesic.c (#2752)
>> o BoundCRS::identify(): avoid incompatible transformation for
>> WKT1 / TOWGS84 export (#2747)
>> o proj_create(): do not open proj.db if string is a PROJ string,
>> even if proj_context_set_autoclose_database() has been set (#2735)
>> o Fix export of transformation to PROJ string in a particular situation
>> where CompoundCRS are involved (#2721)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
