[PROJ] PROJ 8.1.0RC1 & PROJ-data 1.7RC1
Howard Butler
howard at hobu.co
Tue Jun 29 07:12:06 PDT 2021
+1 Howard
> On Jun 29, 2021, at 9:11 AM, Even Rouault <even.rouault at spatialys.com> wrote:
> +1 Even
> Le 29/06/2021 à 16:10, Kristian Evers a écrit :
>> PSC Members,
>> No issues with the two release candidates have been reported so I hereby motion that
>> PROJ 8.1.0RC1 and PROJ-data 1.7RC1 be promoted to their final versions.
>> I’ll start with my +1.
>> /Kristian
>>> On 25 Jun 2021, at 18:31, Kristian Evers <kristianevers at gmail.com> wrote:
>>> All,
>>> I have prepared release candidates for PROJ 8.1.0 and PROJ-data 1.7. Download them here:
>>> http://download.osgeo.org/proj/proj-8.1.0RC1.tar.gz
>>> http://download.osgeo.org/proj/proj-8.1.0RC1.zip
>>> http://download.osgeo.org/proj/proj-data-1.7RC1.tar.gz
>>> http://download.osgeo.org/proj/proj-data-1.7RC1.zip
>>> See the PROJ release notes below. The PROJ-data release includes two new grids:
>>> fr_ign_RAF18b.tif and au_ga_AGQG_20201120.tif. In addition the predecessor for the
>>> latter grid, au_ga_AGQG_20191107.tif, has been removed.
>>> Please test the two release candidates and report back your findings either to the
>>> mailing list or in a GitHub issue.
>>> /Kristian
>>> 8.1.0 Release Notes
>>> Updates
>>> + Database
>>> o Update to EPSG v10.027 (#2751)
>>> o Decrease DB size by using WITHOUT ROWID tables (#2730) (#2647)
>>> o Add a ANALYZE step during proj.db creation allowing for
>>> faster lookups (#2729)
>>> o Added a PROJ.VERSION metadata entry (#2646)
>>> o Added NGO48 (EPSG:4273) to ETRS89 (EPSG:4258) triangulation-based
>>> transformation (#2554)
>>> o Additions to the norwegian NKG2020 transformation (#2548)
>>> o ESRI projection database updated to version 12.8 (#2717)
>>> + API additions
>>> o Added proj_get_geoid_models_from_database() function that returns a list of
>>> geoid models available for a given CRS (#2681)
>>> o Added proj_get_celestial_body_list_from_database that returns a list
>>> of celestial bodies in the PROJ database (#2667)
>>> o Added proj_get_celestial_body_name() (#2662)
>>> + Various improvements
>>> o proj_trans/cs2cs: If two operations have the same accuracy,
>>> use the one that is contained within a larger one (#2750)
>>> o Share SQLite database handle among all contexts (#2738)
>>> o Add proj/internal/mutex.hpp as compat layer for mingw32 for std::mutex (#2736)
>>> o projsync: make it filter out files not intended for the current version (#2725)
>>> o Improvements related to DerivedVerticalCRS using Change Unit and
>>> Height/Depth reversal methods (#2696)
>>> o Update internal nlohmann/json to 3.9.1, and add a CMake option to
>>> be able to use external nlohmann/json (#2686)
>>> o createFromUserInput(): change name of CRS built from URN combined references to match the convention of EPSG projected CRS (#2677)
>>> o Parse compound id with two authorities, like ESRI:103668+EPSG:5703 (#2669)
>>> o Added projinfo option --list-crs (supports --area) (#2663)
>>> o Added support for hyperbolic Cassini-Soldner (#2637)
>>> o Added capability to get SQL statements to add custom CRS in the database (#2577)
>>> Bug fixes
>>> o Fix 'Please include winsock2.h before windows.h' warning with msys (#2692)
>>> o Minor changes to address lint in geodesic.c (#2752)
>>> o BoundCRS::identify(): avoid incompatible transformation for
>>> WKT1 / TOWGS84 export (#2747)
>>> o proj_create(): do not open proj.db if string is a PROJ string,
>>> even if proj_context_set_autoclose_database() has been set (#2735)
>>> o Fix export of transformation to PROJ string in a particular situation
>>> where CompoundCRS are involved (#2721)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
More information about the PROJ
