[PROJ] PROJ resources version stability
Even Rouault even.rouault at spatialys.com
Fri Mar 5 03:07:10 PST 2021
Søren,
Le 05/03/2021 à 11:39, Søren Holm a écrit :
> Are the resources distributed with PROJ stable to be used across PROJ
> versions? Can resources from 6.x be used with 8.x?
Yes, you can still use the proj-datumgrid-XXXX packages that use grids
in the formats NTv2, GTX, etc. with PROJ 8, although for optimal results
you should now use the proj-data package that contain a more
comprehensive set of grids in GeoTIFF format.
Even
http://www.spatialys.com
More information about the PROJ mailing list
