[PROJ] PROJ resources version stability
Søren Holm
sgh at sgh.dk
Fri Mar 5 03:09:33 PST 2021
Ok. How about proj.db and the vast majority of files usually located in /share/
proj/ ?
fredag den 5. marts 2021 12.07.10 CET skrev Even Rouault:
> Søren,
> Le 05/03/2021 à 11:39, Søren Holm a écrit :
> > Are the resources distributed with PROJ stable to be used across PROJ
> > versions? Can resources from 6.x be used with 8.x?
> Yes, you can still use the proj-datumgrid-XXXX packages that use grids
> in the formats NTv2, GTX, etc. with PROJ 8, although for optimal results
> you should now use the proj-data package that contain a more
> comprehensive set of grids in GeoTIFF format.
> Even
Søren Holm
More information about the PROJ
