[PROJ] Get PROJ description in PROJ 5?
Matthew Woehlke mwoehlke.floss at gmail.com
Fri Mar 19 08:59:24 PDT 2021
In PROJ 4, I could get a description of a projection using pj_get_def.
In PROJ 6, I can use proj_as_proj_string.
However, proj_as_proj_string doesn't exist in PROJ 5? How can I get the
description of a PROJ in PROJ 5?
proj_pj_info does not seem to work (the definition I get back is empty,
at least in PROJ 6; does this function behave differently in PROJ 5?).
Matthew
More information about the PROJ mailing list
