[PROJ] Building with VC 10 Express
Charles Karney
charles at karney.com
Fri Mar 26 06:15:20 PDT 2021
Sorry, I'm not able to diagnose your problem directly. However,
nowadays, the supported versions of Visual Studio are 2015 or later. So
maybe try again with one of these versions of Visual Studio.
On 3/22/21 3:52 PM, dp wrote:
> Hello, I am just starting with the Proj libraries and have run into a wall immediately. I wrote a single-line program just to get my feet wet -- a call to proj_context_create() -- and while it compiles without any errors, on load it fails with "The application was unable to start correctly (0xc000007b)".
> I am working with Win 7 Pro, 64-bit, SP1, VC 2010 Express. The libraries are the ones installed with the 32-bit version of OSGeo4W I installed for this purpose. The version of proj.exe that came with it is 6.3.2.
> Thanks.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
Charles Karney <charles at karney.com>
Princeton, NJ
More information about the PROJ
