[PROJ] RE(2): RD NAP + TRANS usage.
Lesparre, Jochem
Jochem.Lesparre at kadaster.nl
Fri May 7 06:19:34 PDT 2021
Hi David,
Note that the files 002_ETRS89.TXT and 002_RDNAP.TXT do not contain coordinates of the same points! If you want a data set with corresponding coordinates of the same points, you can use the file Z001_ETRS89andRDNAP.TXT, which is available here:
https://www.nsgi.nl/geodetische-infrastructuur/producten/programma-rdnaptrans/zelfvalidatie
I hope that solves your problem. If it does, suggestions on how to improve our documentation a nsgi.nl to prevent others from having the same confusion are most welcome.
Kind regards, Jochem
J. Lesparre
Geodetic Engineer (MSc)
Kadaster | Rijksdriehoeksmeting
+31-88-183 20 00 | rd at kadaster.nl<mailto:rd at kadaster.nl>
Netherlands Partnership Geodetic Infrastructure
Disclaimer:
De inhoud van dit bericht is uitsluitend bestemd voor geadresseerde.
Gebruik van de inhoud van dit bericht door anderen zonder toestemming van het Kadaster
is onrechtmatig. Mocht dit bericht ten onrechte bij u terecht komen, dan verzoeken wij u
dit direct te melden aan de verzender en het bericht te vernietigen.
Aan de inhoud van dit bericht kunnen geen rechten worden ontleend.
Disclaimer:
The content of this message is meant to be received by the addressee only.
Use of the content of this message by anyone other than the addressee without the consent
of the Kadaster is unlawful. If you have received this message, but are not the addressee,
please contact the sender immediately and destroy the message.
No rights can be derived from the content of this message.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210507/d220f40e/attachment.html>
More information about the PROJ
