[PROJ] Fwd: EPSG v10.021: 3 issues
Even Rouault even.rouault at spatialys.com
Thu May 13 13:27:37 PDT 2021
In case someone else would try to integrate it.
-------- Message transféré --------
Sujet : 	EPSG v10.021: 3 issues
Date : 	Thu, 13 May 2021 19:09:00 +0200
De : 	Even Rouault <even.rouault at spatialys.com>
Pour : 	feedback at epsg.org
Hello,
Using the PostgreSQL dump of EPSG v10.021, I've identified the 3
following issues:
- null (in a SQL meaning, not 0) parameter values for the translation
values of the 3 Helmert transformations EPSG:1076 "PSAD56 to WGS 84
(13)", EPSG:1077 "La Canoa to WGS 84 (2)" and EPSG:1581 "SIRGAS 1995 to
WGS 84 (1)".
- transformation EPSG:9728 "ETRS89 to Cagliari 1956 height (1)" lacks a
parameter value for the grid name
- null parameter value for the 'False northing' parameter of conversion
EPSG:12103 "Michigan State Plane West zone"
Best regards,
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20210513/ad67fa72/attachment.html>
More information about the PROJ mailing list
