[PROJ] Need for New CRS's with default datum transformation in PROJ with EPSG 6206 for North Macedonian three CRSs'
Mike Taves
mwtoews at gmail.com
Thu Apr 7 13:58:42 PDT 2022
On Fri, 8 Apr 2022 at 06:11, Even Rouault <even.rouault at spatialys.com> wrote:
> Do you have any other idea?
> No, that's an hard topic. No easy solution. The solution might be that QGIS would be modified to no longer select the default transformation proposed by PROJ, and instead lets PROJ decide at conversion time which transformation to apply for each point. But that won't be perfect either, given that PROJ only uses a bounding box approach, and not the polygonal shape of the extents.
See also https://github.com/OSGeo/PROJ/issues/1461
More information about the PROJ
