[PROJ] fliemanager.cpp build issue
Even Rouault
even.rouault at spatialys.com
Mon Jan 17 09:35:55 PST 2022
Gordon,
can you try adding #define _GNU_SOURCE at the top of filemanager.cpp ?
Even
Le 17/01/2022 à 18:30, gordon frisbie a écrit :
> While building PROJ the compilation crashes while trying to build
> filemanager.cpp. I'm using Cygwin on a Windows Server 2012
> machine. It appears that the build is bypassing the "#if
> __GNU_VISIBLE" condition in Cygwin's dlfcn.h file.
> filemanager.cpp:1344:5: error: ‘Dl_info’ was not declared in this scope
> 1344 | Dl_info info;
> filemanager.cpp:1345:60: error: ‘info’ was not declared in this scope
> 1345 | if (!dladdr((const void *)pj_get_relative_share_proj, &info)) {
> filemanager.cpp:1345:10: error: ‘dladdr’ was not declared in this scope
> filemanager.cpp:1348:21: error: ‘info’ was not declared in this scope
> 1348 | std::string out(info.dli_fname);
> Thanks,
> Gordon
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220117/af799cd1/attachment.html>
More information about the PROJ
