[PROJ] Fwd: some help with cm-level GRS80 to WGS-84 transformation?
Joseph Boardman boardman at aigllc.com
Wed Jan 19 12:25:06 PST 2022
-------- Forwarded Message --------
Subject: 	some help with cm-level GRS80 to WGS-84 transformation?
Date: 	Wed, 19 Jan 2022 11:28:24 -0700
To: 	proj at lists.osgeo.org
Dear Proj Experts,
I'm a remote sensing geophysicist with experience in geodesy and mapping.
Right now I'm struggling trying to get a high-accuracy proj command to
convert from GRS80 to WGS-84 at the cm level.
Any clues? cs2cs is not doing it.
cs2cs +proj=lonlat +ellps=WGS84 +to +proj=lonlat +ellps=GRS80 -d 8
-120 40
-120.00000000 40.00000000 0.00000000
Do I need to do a transformation pipeline per the 8.2.1 docs and use a
Helmert transform? Any help much appreciated.
Best,
Joe
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220119/14da6468/attachment.html>
More information about the PROJ mailing list
