[PROJ] CRS explorer
Javier Jimenez Shaw
j1 at jimenezshaw.com
Tue Mar 1 12:27:23 PST 2022
Hi PROJ community
https://jjimenezshaw.github.io/crs-explorer is now updated to PROJ 9.0.0
It also includes some improvements (some of them suggested by you), like:
- Single table, having a column with the type.
- WKT 1&2 links to plain text urls (I made that way to easily link to the
wkt files from anywhere just knowing the code). It also tries to display it
as a tooltip, if the browser doesn't bother too much.
- Persistent URL while you update the filters: makes easy to share your
selection.
- Direct link to epsg.org description of each crs (well, this change is a
bit older).
It now has 12869 systems (enable them all with
https://jjimenezshaw.github.io/crs-explorer/?all=true ).
I hope it become more useful.
Cheers,
Javier.
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
Entre dos pensamientos racionales
hay infinitos pensamientos irracionales.
On Sun, 5 Dec 2021 at 11:18, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> On Sat, 4 Dec 2021 at 13:54, Lesparre, Jochem <Jochem.Lesparre at kadaster.nl>
> wrote:
>> Hi Javier,
> Jochem, Thanks for you answer and suggestions.
> Thanks for the nice improvements. I like the name filtering! It could be
>> useful to be able to use this for other columns too, like the area of use
>> and code.
> I thought about that, but finally decided not doing it. When you search
> for the code, you want a single result (you don't want to "filter"): Ctrl+F
> does that much better ;) About the area of use, their names are really
> confusing sometimes. And it may collide with the CRS name. Picking a point
> in the map would be better IMO.
> BTW, the filter field tries to work like many search engines: use
> double-quotes (") for searches with spaces, and a dash (-) to implement a
> "not" filter... and combine as many as you want. It is explained in the
> info (i) link.
>> I was wondering: Since you give the option to sort on a column, why do
>> you present the CRS types (Projected, Geographic, Geocentric etc.) in
>> separate tables? If you add a column for the CRS type in the table, then
>> you could present everything in a single table and an user can still sort
>> on CRS type if needed. The advantage would be that the user can also sort
>> on other columns for all CRS types at once.
> Yes, it was also in the backlog of ideas. I would give the option to
> display one way or the other, but may take some time to implement (yes, I
> like giving options to the user... and later they ask what does it do ;).
>> What does the option Sticky map do?
> "Sticks" the map to the top of the viewport when you scroll down due to a
> large table. See next answer.
> What function does the checkbox in the column Area of use have?
> Displays a green rectangle in the map with the area(s) of use selected.
> Just hovering with the mouse shows an orange rectangle. Now you understand
> why you need the sticky map option.
>> Regards, Jochem
> Cheers,
> Javier.
>> *From:* PROJ <proj-bounces at lists.osgeo.org> on behalf of Javier Jimenez
>> *Sent:* Friday, 3 December 2021, 16:01
>> *To:* proj
>> *Subject:* Re: [PROJ] CRS explorer
>> Hi all
>> Sorry for the late update to PROJ 8.2.0. I have been implementing it with
>> GitHub Actions. But now it is available.
>> Some features were added, like filtering by name, column ordering, better
>> performance...
>> I was thinking on adding links to static pages with the WKT1 of each CRS.
>> Do you think it is useful?
>> Cheers,
>> Javier
>> PS: I found some new astronomical CRSs (IAU_2015) that are type "other"
>> in proj.db. What is that?
>> On Thu, 14 Oct 2021 at 12:57, Thomas Knudsen <knudsen.thomas at gmail.com>
>> wrote:
>> Javier,
>> Thanks for developing this - it seems to be extremely useful!
>> /Thomas
>> Den tor. 14. okt. 2021 kl. 12.03 skrev Javier Jimenez Shaw <
>> j1 at jimenezshaw.com>:
>> Hi
>> I have developed a simple webpage to search coordinate reference systems
>> based on PROJ data. It includes a map where you can click a location,
>> filtering the systems that has this location in their area of use.
>> There are a couple of ideas to add in the backlog. But I hope it is
>> already useful.
>> Cheers,
>> Javier.
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
>> Disclaimer:
>> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
>> geadresseerde(n).
>> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
>> verstrekking van deze informatie aan derden is niet toegestaan.
>> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
>> van toepassing
>> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
>> Disclaimer:
>> This email and any files transmitted with it are confidential and
>> intended solely for the use of the individual or entity to whom they are
>> addressed.
>> If you are not the intended recipient, you are notified that disclosing,
>> copying, distributing or taking any action in reliance on the contents of
>> this information is strictly prohibited.
>> Our general terms and conditions of delivery apply to all our products
>> and services
>> [https://www.kadaster.com/general-terms-and-conditions].
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220301/8a9a4b08/attachment.html>
More information about the PROJ
