[PROJ] Krovak S-JTSK centimeter accuracy
    Erixen Cruz
    erixen at cesium.com
    Wed Mar 16 11:30:07 PDT 2022
> What do you mean by local: a grid that deal with projected coordinates ?
> Is it really the case here ?
Yes, it is in projected coordinates with corrections in the X and Y
directions (easing, northing). I was thinking of reprojecting to geodetic
coordinates to be able to use `hgridshift`, but there is nuance/complexity
like you mentioned.
OK, so "standard grids" here. Are they the same you referred too previously
They are different from the published files mentioned previously that are
in projected coordinates. These are grids that PROJ knows how to handle.
I would strongly suggest that you, or more appropriately the Czech geodesic
> authority register those grids with IOGP in the EPSG dataset.
That makes sense. These "standard grids" come from researchers from Czech
universities, and the most accurate one has an MIT-like (open) license. We
can just use it by adding it to the PROJ_LIB directory with the rest of the
other files that come with proj-data.
Thanks for your insight, Even.
Sincerely, Erixen
On Wed, Mar 16, 2022 at 2:07 PM Even Rouault <even.rouault at spatialys.com>
wrote:
> First question:
> Does Proj support this local coordinate grid shift?
> Is it really the case here ? (sorry didn't have time to read thoroughly
> your links). We've had instances where the data producer originally
> provided grids referenced to projected coordinates, like the OSGB15 geoid
> model, and the contributor to PROJ-data reprojected them to geographic
> coordinates to make them more usable by PROJ. Of course this only worked
> for a geoid model. If the content of the grid itself is shifts in eastings,
> northings, then a more complex transformation has to be done. Otherwise
> PROJ would need a few changes to deal with grids that would operate on
> Second question:
> The Czech Technical University in Prague has a page about using Proj to
> transform to/from S-JTSK here
> <http://freegis.fsv.cvut.cz/gwiki/S-JTSK_/_Grid> (English
> <https://freegis-fsv-cvut-cz.translate.goog/gwiki/S-JTSK_/_Grid?_x_tr_sch=http&_x_tr_sl=auto&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=wapp>).
> It suggests using grid shift files from some CZ researchers with the old
> `nadgrids` and `geoidgrids` paradigm.
> previously ?
> would Proj accept a PR for adding these grid shift files to get the better
> accuracy?
> geodesic authority register those grids with IOGP in the EPSG dataset.
> That's the main source of geodesic data for PROJ. Otherwise we need to add
> custom entries, and this adds a maintenance burden to the project. If you'd
> want those grid(s) to be included in https://github.com/OSGeo/PROJ-data/,
> you'll have also to make sure that they are licensed under an open data
> license such as the ones listed in
> https://github.com/OSGeo/PROJ-data/#about-the-data-package. It can take
> some time of discussion with the data producer so 1) they are aware about
> the existence of licenses 2) they are willing to distribute under an open
> data license.
> Even
> Thanks for reading, and thanks for any advice you can offer.
> Sincerely,
> Erixen Cruz
> 3D Software Developer, Cesium <https://cesium.com/>
> PROJ mailing listPROJ at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/proj
> -- http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220316/f83f19ac/attachment-0001.html>
More information about the PROJ
