[PROJ] Dealing with epoch and transformations
Even Rouault even.rouault at spatialys.com
Fri Aug 23 13:17:26 PDT 2024
Javier,
Regarding intra-ITRF transformations, the EPSG database lacks the ITRF
plate motion models. We do have them (up to ITRF2014) in the
data/ITRFxxxx files (cf the link to a previous thread of mine that Jack
Riley has quoted). I see we don't have yet the ITRF2020 ones. They are
at https://itrf.ign.fr/docs/solutions/itrf2020/ITRF2020-PMM.dat
For a fully automated solution what would be mostly missing in PROJ is
support for non-rectangular area of interest, as the rectangular model
could be very inadequate for parts of the world
Even
Le 23/08/2024 à 11:28, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> I am a bit confused with the epoch of coordinates. For instance, if I
> connect to this NTRIP service
> https://support.swiftnav.com/support/solutions/articles/44002386941-configuring-your-receiver
> it says explicitly that "Skylark Nx RTK uses ITRF2020 reference frame."
> Does it mean that the coordinates that I measure today do have an
> epoch of 2024.x (today's epoch), or the epoch of those measurements is
> 2015.0 (the epoch of ITRF2020
> https://epsg.org/datum_1322/International-Terrestrial-Reference-Frame-2020.html)
> If I want to transform from that reference system (ITRF2020) to, let's
> say, ETRS89 or NAD83(2011), should I add an epoch? which one? where?
> what happens if I do not set any?
> I have the impression that I could convert from one epoch to another
> for the same CRS, something like this
> PROJ_DATA=data ./bin/projinfo -s EPSG:9989 -t EPSG:9989 --s_epoch
> 2015.0 --t_epoch 2020.0 -o proj
> Candidate operations found: 1
> Operation No. 1:
> unknown id, Null geographic offset from ITRF2020 to ITRF2020, 0 m, World.
> PROJ string:
> +proj=noop
> ... but it does not. Should it do a non noop transformation?
> Note: s_epoch and t_epoch were added in PROJ 9.4
> Thanks.
> PS. ITRF2020 to CH1903+ is a complete ballpark :(
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __.. ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240823/5f966127/attachment.htm>
More information about the PROJ mailing list
