[PROJ] Dealing with epoch and transformations
Even Rouault
even.rouault at spatialys.com
Mon Aug 26 15:53:06 PDT 2024
Le 23/08/2024 à 22:17, Even Rouault via PROJ a écrit :
> Javier,
> Regarding intra-ITRF transformations, the EPSG database lacks the ITRF
> plate motion models. We do have them (up to ITRF2014) in the
> data/ITRFxxxx files (cf the link to a previous thread of mine that
> Jack Riley has quoted). I see we don't have yet the ITRF2020 ones.
> They are at https://itrf.ign.fr/docs/solutions/itrf2020/ITRF2020-PMM.dat
I've created the ITRF2020 file in
https://github.com/OSGeo/PROJ/pull/4235. I've double checked him, but
triple checking could be useful for the plate motion part, as it is easy
to get an extra or missing decimal, or getting a sign wrong when porting
from the PDF to the file...
> For a fully automated solution what would be mostly missing in PROJ is
> support for non-rectangular area of interest, as the rectangular model
> could be very inadequate for parts of the world
> Even
> Le 23/08/2024 à 11:28, Javier Jimenez Shaw via PROJ a écrit :
>> Hi
>> I am a bit confused with the epoch of coordinates. For instance, if I
>> connect to this NTRIP service
>> https://support.swiftnav.com/support/solutions/articles/44002386941-configuring-your-receiver
>> it says explicitly that "Skylark Nx RTK uses ITRF2020 reference frame."
>> Does it mean that the coordinates that I measure today do have an
>> epoch of 2024.x (today's epoch), or the epoch of those measurements
>> is 2015.0 (the epoch of ITRF2020
>> https://epsg.org/datum_1322/International-Terrestrial-Reference-Frame-2020.html)
>> If I want to transform from that reference system (ITRF2020) to,
>> let's say, ETRS89 or NAD83(2011), should I add an epoch? which one?
>> where? what happens if I do not set any?
>> I have the impression that I could convert from one epoch to another
>> for the same CRS, something like this
>> PROJ_DATA=data ./bin/projinfo -s EPSG:9989 -t EPSG:9989 --s_epoch
>> 2015.0 --t_epoch 2020.0 -o proj
>> Candidate operations found: 1
>> Operation No. 1:
>> unknown id, Null geographic offset from ITRF2020 to ITRF2020, 0 m, World.
>> PROJ string:
>> +proj=noop
>> ... but it does not. Should it do a non noop transformation?
>> Note: s_epoch and t_epoch were added in PROJ 9.4
>> Thanks.
>> PS. ITRF2020 to CH1903+ is a complete ballpark :(
>> .___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240827/b0a17835/attachment.htm>
More information about the PROJ
