[PROJ] ISEA projection: proposed parameters deprecation and input latitude interpretation
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Tue Aug 27 02:20:16 PDT 2024
Hi Jérôme,
this is all very logical, dropping those DGGS paramaters and adding azi= instead.
I wonder whether the angular coordinates interpretation shouldn't also be left to the user to decide. Eventually with the authalic transformation as default behaviour.
Regards.
Mastodon: https://mastodon.social/@luis_de_sousa
URL: https://ldesousa.codeberg.page
Sent with [Proton Mail](https://proton.me/) secure email.
On Saturday, 24 August 2024 at 15:36, Jérôme St-Louis via PROJ <proj at lists.osgeo.org> wrote:
> Dear PROJ community,
> I recently had the chance to integrate an implementation of the inverse transformation for the [Icosahedral Snyder Equal-Area (ISEA) projection](https://proj.org/en/9.4/operations/projections/isea.html) ([PR #4211](https://github.com/OSGeo/PROJ/pull/4211) which was recently merged).
> Doing so resulted in some initial re-factoring to share code between the forward and inverse projection.
> Deprecating grid parameters
> During this process, I realized that several parameters for the projection (+proj=isea) really have nothing to do with the projection itself, but are parameters for constructing discrete global grids on top of an ISEA projection.
> In fact, [the code applying these parameters](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L931) happens as a later step after the default planar projection (with the exception of the trivial [isea_tri_plane()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L656)).
> Therefore, I suggest this code really does not belong in the PROJ library, but outside, in the implementation of a discrete global grid system, such as in libraries like [DGGRID](https://github.com/sahrk/DGGRID) and [geogrid](https://github.com/mocnik-science/geogrid/), and these parameters should be deprecated.
> In addition:
> - there is no documentation at all for the parameters and they are very poorly understood,
> - there are no existing tests for these parameters,
> - the new inverse transformation does not support these parameters.
> The three parameters proposed for deprecation are:
> +mode which can be set to plane (the default), di, dd, or hex
> The default mode is plane which would become the only thing supported.
> hex referred to returning coordinates related to a hexagonal grid, but it is really not clear.
> di and dd seemed to refer to a rhombus grid, in a way very similar to the approach we use for an [ISEA9R DGGRS](https://docs.ogc.org/DRAFTS/21-038.html#isea9r-dggrs) (or ISEA4R for a quad-tree).
> The ISEA planar projection can be very easily transformed to a space where icosahedron triangles merge into 10 axis-aligned rhombuses by applying a 60 degrees rotation and 30 degrees horizontal shearing, which can be done with +proj=affine.
> This seems to be what [isea_ptdd()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L669) is doing for dd.
> di seems to be referring to an extra step done in [isea_ptdi()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L849). I have no idea what this is doing.
> +aperture which is the aperture (refinement ratio) of the discrete global grid for those di, dd and hex modes
> +resolution which I am not sure how it affects the di, dd, and hex modes, but is only used with those modes proposed for deprecation
> Systems using these parameters could still extract the code for these extra steps in its [current state](https://github.com/OSGeo/PROJ/blob/2ce6c7a9b1ca44b8a7cfb1acca7ff10c8c616774/src/projections/isea.cpp), and invoke as an extra step after the planar projection (after undoing the trivial 180 deg rotation and translation that [isea_tri_plane()](https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L656) is doing).
> If you make use of these parameters and object to their deprecation, please reply with feedback.
> I plan to submit a pull request for a staged deprecation, which first mentions in the documentation that these parameters will be deprecated in a future version.
> On the flip side, I hope to eventually contribute support for the remaining +azi= parameter not yet supported by the inverse projection (which allows support for orientations such as the R. Buckminster Fuller's Dymaxion Orientation).
> Possibly also eventually allowing to specify an arbitrary latitude and longitude for the first icosahedron vertex, as opposed to the two available options of +orient=pole and +orient=isea with fixed values.
> Proposing to interpret input latitude as authalic latitude
> As [discussed in the PR](https://github.com/OSGeo/PROJ/pull/4211#issuecomment-2275206640), the ISEA projection is only defined on a sphere.
> Although I clarified this in the [documentation](https://osgeo-proj--4211.org.readthedocs.build/en/4211/operations/projections/isea.html), the most common use case is having geodetic WGS84 latitude and longitude coordinates which you want to project to the ISEA planar projection.
> This includes the use case of integrating data into a discrete global grid system using a DGGRS based on the ISEA projection, such as ISEA3H or ISEA9R.
> Before applying the spherical projection with a sphere whose surface area is the same as the GRS80 or WGS84 ellipsoid (authalic sphere), the geodetic latitude should be converted to an [authalic latitude](https://en.wikipedia.org/wiki/Latitude#Authalic_latitude).
> This is already done by PROJ in other projections, including the Lamber Azimuthal Equal-Area projection of which ISEA is modified form, if I understand correctly (see https://github.com/OSGeo/PROJ/blob/master/src/projections/laea.cpp#L38 and https://github.com/OSGeo/PROJ/pull/4211#issuecomment-2284383509 ).
> I propose that the geodetic latitude be automatically converted to an authalic latitude when using the projection with a non-spherical ellipsoid (which is the default, and therefore currently quite prone to misuse).
> Please reply if you see any issue with this change, for which I also plan to submit a pull request.
> Thank you very much!
> Kind regards,
> -Jerome
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240827/8378eee6/attachment-0001.htm>
More information about the PROJ
