[PROJ] ISEA projection: proposed parameters deprecation and input latitude interpretation
Jérôme St-Louis
jerome at ecere.com
Sat Aug 24 07:36:38 PDT 2024
Dear PROJ community,
I recently had the chance to integrate an implementation of the inverse
transformation for the Icosahedral Snyder Equal-Area (ISEA) projection
<https://proj.org/en/9.4/operations/projections/isea.html> (PR #4211
<https://github.com/OSGeo/PROJ/pull/4211> which was recently merged).
Doing so resulted in some initial re-factoring to share code between the
forward and inverse projection.
*Deprecating grid parameters*
During this process, I realized that several parameters for the
projection (+proj=isea) really have nothing to do with the projection
itself, but are parameters for constructing discrete global grids on top
of an ISEA projection.
In fact, the code applying these parameters
<https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L931>
happens as a later step after the default planar projection (with the
exception of the trivial isea_tri_plane()
<https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L656>).
Therefore, I suggest this code really does not belong in the PROJ
library, but outside, in the implementation of a discrete global grid
system, such as in libraries like DGGRID
<https://github.com/sahrk/DGGRID> and geogrid
<https://github.com/mocnik-science/geogrid/>, and these parameters
should be deprecated.
In addition:
- there is no documentation at all for the parameters and they are very
poorly understood,
- there are no existing tests for these parameters,
- the new inverse transformation does not support these parameters.
The three parameters proposed for deprecation are:
*+mode* which can be set to /plane/ (the default), /*di*/, */dd/*, or
/*hex*/
The default mode is /plane/ which would become the only thing
supported.
/hex/ referred to returning coordinates related to a hexagonal grid, but
it is really not clear.
/di/ and /dd/ seemed to refer to a rhombus grid, in a way very similar
to the approach we use for an ISEA9R DGGRS
<https://docs.ogc.org/DRAFTS/21-038.html#isea9r-dggrs> (or ISEA4R for a
quad-tree).
The ISEA planar projection can be very easily transformed to a
space where icosahedron triangles merge into 10 axis-aligned rhombuses
by applying a 60 degrees rotation and 30 degrees horizontal shearing,
which can be done with +proj=affine.
This seems to be what isea_ptdd()
<https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L669>
is doing for /dd/.
/di/ seems to be referring to an extra step done in isea_ptdi()
<https://github.com/OSGeo/PROJ/blob/master/src/projections/isea.cpp#L849>.
I have no idea what this is doing.
*+aperture* which is the aperture (refinement ratio) of the discrete
global grid for those di, dd and hex modes
*+resolution* which I am not sure how it affects the di, dd, and hex
modes, but is only used with those modes proposed for deprecation
Systems using these parameters could still extract the code for these
extra steps in its current state
<https://github.com/OSGeo/PROJ/blob/2ce6c7a9b1ca44b8a7cfb1acca7ff10c8c616774/src/projections/isea.cpp>,
and invoke as an extra step after the planar projection (after undoing
the trivial 180 deg rotation and translation that isea_tri_plane()
is doing).
If you make use of these parameters and object to their deprecation,
please reply with feedback.
I plan to submit a pull request for a staged deprecation, which first
mentions in the documentation that these parameters will be deprecated
in a future version.
On the flip side, I hope to eventually contribute support for the
remaining *+azi*= parameter not yet supported by the inverse projection
(which allows support for orientations such as the R. Buckminster
Fuller's Dymaxion Orientation).
Possibly also eventually allowing to specify an arbitrary latitude and
longitude for the first icosahedron vertex, as opposed to the two
available options of +orient=pole and +orient=isea with fixed values.
Proposing to interpret input latitude as authalic latitude*
As discussed in the PR
<https://github.com/OSGeo/PROJ/pull/4211#issuecomment-2275206640>, the
ISEA projection is only defined on a sphere.
Although I clarified this in the documentation
<https://osgeo-proj--4211.org.readthedocs.build/en/4211/operations/projections/isea.html>,
the most common use case is having geodetic WGS84 latitude and longitude
coordinates which you want to project to the ISEA planar projection.
This includes the use case of integrating data into a discrete global
grid system using a DGGRS based on the ISEA projection, such as ISEA3H
or ISEA9R.
Before applying the spherical projection with a sphere whose surface
area is the same as the GRS80 or WGS84 ellipsoid (authalic sphere), the
geodetic latitude should be converted to an authalic latitude
<https://en.wikipedia.org/wiki/Latitude#Authalic_latitude>.
This is already done by PROJ in other projections, including the Lamber
Azimuthal Equal-Area projection of which ISEA is modified form, if I
understand correctly (see
https://github.com/OSGeo/PROJ/blob/master/src/projections/laea.cpp#L38
and https://github.com/OSGeo/PROJ/pull/4211#issuecomment-2284383509 ).
I propose that the geodetic latitude be automatically converted to an
authalic latitude when using the projection with a non-spherical
ellipsoid (which is the default, and therefore currently quite prone to
misuse).
Please reply if you see any issue with this change, for which I also
plan to submit a pull request.
Thank you very much!
Kind regards,
-Jerome
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240824/ac3eadfc/attachment.htm>
More information about the PROJ
