[PROJ] Ellipsoidal distances, with different heights
Even Rouault
even.rouault at spatialys.com
Tue Aug 27 16:36:10 PDT 2024
Nyall,
I'm not sure there's a real definition to what you want to accomplish.
I guess I would :
- use the geod_position() of geodesic.h to compute a sufficient number
of intermediate positions
- linearly interpolate the ellipsoidal height
- convert the resulting (lon, lat, h) to geocentric (X, Y, Z) using
+proj=cart
- use 3D Cartesian distance to compute each intermediate segment
- sum them up
A cheaper alternative might be to compute the geodesic distance between
the start and end points both on the ellipsoid (a + h_start, b +
h_start) and on the one (a + h_end, b + h_end), and compute some sort of
mean (arithmetic, geometry, ... ?) on those 2 distances.
Even
Le 28/08/2024 à 01:06, Nyall Dawson via PROJ a écrit :
> Hi list,
> Let's say I have two points on an ellipsoid, with each point having a
> different height above the ellipsoid. I want to calculate a kind of
> "geodesic" between these points, where there's an assumption that the
> gradient of the height-above-ellipsoid for the "geodesic" is constant.
> Is this mathematically solvable? Or, more to the point, is it possible
> to calculate this using any of the methods exposed via geodesic.h?
> Nyall
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ
